JWood88 Posted August 28, 2014 Share Posted August 28, 2014 Hello All, I packed my Line 6 up for a move and finally got a chance to pull it out for a jam session with some Pals and to my dismay, I cannot produce distortion without turning the gain up. My Custom presets produce absolutely no distortion, but maintain the custom names I have made. As I switch between them the the various custom presets the lights all change accordingly from one custom preset to the next. None of the pre-programmed presets, ranging from As I lay Dying to Meshuggah have distortion either. Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted August 28, 2014 Share Posted August 28, 2014 Have you backed up your preset patches using Spider Edit? If not, do so, then do a Factory Reset and see if this fixes the problem. Then you'll need to move all your presets back into their locaitons with Spider Edit. Quote Link to comment Share on other sites More sharing options...
JWood88 Posted August 28, 2014 Author Share Posted August 28, 2014 Thank you for the quick response, fflbrgst. I have backed up my presets already and conducted a factory reset last night, but to no avail. I still cannot produce any distortion on any of my channels. Everything comes out "Clean". Pretty frustrating =( Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted August 29, 2014 Share Posted August 29, 2014 Have you manually tried adjusting the fuzz boxes? I assume that is how you are getting distortion. You mentione youhave to turn up the gain - do the settings look correct in your presets, or is hte gain truned down in them? Gain or fuzzbox would be the two methods of getting distortion. Quote Link to comment Share on other sites More sharing options...
JWood88 Posted September 6, 2014 Author Share Posted September 6, 2014 Thank you for your efforts in looking into the matter, Mike. I have adjusted both, and still cannot get the proper sound... well even remotely close to the sound it had before and the issue transpires over to the pre-loaded patches too. I can get every effect but distortion to come through. So even when I go to a patch like, "As I lay dying's" pre-loaded distortion "Shredd", there is still absolutely no distortion to it what-so ever. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted September 8, 2014 Share Posted September 8, 2014 Sounds like you may have a processor problem if nothing comes back after a system reset. Next thing would be to bring it to an authorized service center for evalutation. Quote Link to comment Share on other sites More sharing options...
