markwesse Posted August 31, 2014 Share Posted August 31, 2014 Howdy All Im assuming that the models in pod farm are all at 44k? ie if host sample rate is eg 96k then the models are just resampled? Is this correct? Are the hd (im guessing 96k sample convos) available for pod farm at all? Also, does the 95 dual rec that was on the original pod, exist anywhere else ie that can be used in software? Many thanks Mark Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 31, 2014 Share Posted August 31, 2014 I can answer one of your questions. No, the HD models are not available in any plug-in format, including Pod Farm. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted August 31, 2014 Share Posted August 31, 2014 I'm not an expert but have read on the subject and from what I can gather the higher sample rate is like taking a bigger picture on a camera in essence more information about your music is being collected (recorded) so it would seem that if your going to do alot of editing after you record you would want to use the higher sample rate which is a very large file because of the massive amount of data collected. I don't hear any difference between the low sample and the high sample but when I record something I do it at the highest sample rate my computer can handle and then compress it into a smaller sample. Quote Link to comment Share on other sites More sharing options...
