Digital Clipping in Low Volume Mode
clipping noise digital
2 replies to this topic
#1 dattrax
dattrax
  • 7 posts
  • Registered Products:3
Posted 04 September 2014 - 11:39 AM
Just wanted to post this in case anyone else stumbles across the issue.
I had an issue with really bad digital clipping in low volume mode.  I removed the HD500 from the chain and went straight into the top of the amp, still no luck.  The normal volume mode seemed OK, but low not.  Anyhow, I read in this forum that the low volume mode is modeled and not done via the same signal path so I thought to upgrade the firmware.  I was already on 2.0 (latest), but I went for the reflash anyway.  When the amp came back up again, everything was back to normal, so either the program in the flash or some settings had been corrupted.
Cheers,
Jim
  • 2
#2 Lution777
Lution777
  • 67 posts
Posted 04 September 2014 - 08:46 PM
Interesting. I noticed this today too. Digital clipping in the overdriven amps in low power mode. I just upgraded to 2.0 today. Perhaps I'll perform a reflash as well. Do you know if your saved amps were still saved after reflashing?
#3 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2291 posts
  • LocationU.S.A.
  • Registered Products:16
Posted 06 September 2014 - 03:55 PM
Sometimes you just have to re-flash to fix it. I've been there not for the exact problem though.
