showmpiano Posted September 6, 2014 Share Posted September 6, 2014 I'm just wondering: Are the Analog Out Jacks on the UX1 Stereo or mono? Should I use a cable with stereo or mono plugs? The manual doesn't specify it. Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted September 6, 2014 Share Posted September 6, 2014 They are TRS (the plug looks like stereo, but it's not). There is no advantage to using TRS cables though unless the receiving end is also TRS, AND your cable runs are long. You're probably fine with TS (mono) cables. I use standard TS cables with my UX2 with good results. TRS is pretty much the 1/4" equivalent of XLR. It has noise reduction properties, which normally aren't apparent over short runs. Quote Link to comment Share on other sites More sharing options...
showmpiano Posted September 6, 2014 Author Share Posted September 6, 2014 Ok. I've finally found some mono cables I don't need adapters for. I hope they work. Quote Link to comment Share on other sites More sharing options...
