Buzzing Sound with HD 500
EarthyMusic
I'm having trouble with a buzzing sound on my HD 500.  On a clean setting, it's more of a hiss, but once you turn on distortion, it's more of a buzz (or buzz kill, as the case may be!).
It seems like a grounding issue with the device.  No matter where I'm playing--at home, in the rehearsal studio, or at gigs--it's the same thing.  This leads me to think it's not a problem with the quality of the electricity.
I play through a few different amps, from tube to solid state, depending on the situation.  Always the same problem.  Also, I still get it using different guitars--Les Paul or Strat, it's the same thing.
The buzzing is worse when I have the USB cable connected.  It's also worse when I use distortion--the more distortion, the worse it is.
I was doing some searches on this, and I see that other people have similar problems.  I've tried re-setting the global settings, but no joy.
I'm using the 1/4" input.
Anyone have any ideas?
Are you around something that may be injecting RF into the mix? I had this symptom once, reinstalled the firmware without saving patches and it was fine after that. Don't ask me why 'cause I don't know. Maybe a bad patch corrupted the brain.
