POD HD400 sound through computer
epiphoneman1
First, my apologies if this post already exists.
It's been a while since I have utilized my POD HD400, but I hooked it up to my laptop last night via the USB cable.  However, when I try and play, no sound is emitted from the laptop speakers.  Basically, I would like to listen to the sounds as I work in POD Edit.  Shouldn't I be able to hear through my laptop speakers or when I plug in headphones directly to the laptop (is sound transmitted through the USB cable)?
Starting off, I ensured that the volume was up on the laptop as well as on my guitar and the Pod.  I synced it with the Line 6 Monkey and made sure that everything was up to date with the latest drivers, etc.  I've played around with the Sound settings (Control Panel>Sound), and made sure Line 6 Pod was selected on the recording tab, and that computer speakers were selected on the Playback tab.
I cannot figure out why sound is not being transmitted.
not certain on the 400 but with the 500 it becomes the soundcard and you need to either plug your speakers into the 400 or go into control panel and configure your sound options to let the sound play through the computer speakers.  Hope that made sense...
BUT - HD Edit has no sound capabilities so you would have to run your 400 into a DAW while editing with HD Edit... and configure your DAW output correctly.
