vaud Posted September 25, 2014 Share Posted September 25, 2014 is it possible to record inputs at a level and NOT have them come out of the PA at that level? For example, I have four horns, drums, acoustic guitar and two vocals. Can I record the whole set up but only put the vocals and guitar through the PA? On a traditional board, you would bus them together and send them to the recorder and then turn them down in the main output but I can't find a way to do that on this board. Any suggestions? Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted September 25, 2014 Share Posted September 25, 2014 M20d recording takes place directly at the input, ie raw. Any processing you apply does not form part of the recorded wav file, so you can set the output gain for any channel to zero if that is what you want to do without it affecting the recording. You DO, however, need to trim the inputs. Recording takes place post trim IIRC. Quote Link to comment Share on other sites More sharing options...
