HD300 USB not working
manieldrilla
You could probably shoehorn in many different USB connectors but the one in the link above has the same footprint as the original and will solder right into the HD300 PCB. There are probably others that will do the same. There are others that will fit the USB cable (since that's standard) but will have different PCB connections. But it certainly wouldn't hurt to open the old printer to see if it might fit.
Also, per the on-line video the usb chip controller also requires replacement.
There is another video where the guy says it fixed it but doesn't show it working.
You might be lucky and it is just the connector.
I'd also buy it for less than $130 when you consider how much a new HD500 is
at sweatwater!
