Rick_Auricchio Posted September 30, 2014 Share Posted September 30, 2014 The list of available setups or scenes should NOT be enabled for selection until the user taps LOAD. If I tap another setup name, then tap SAVE, this causes confusion. Does the mixer save my current setup to the one I inadvertently selected? (Luckily it does not.) For example: - I have setup "A" loaded. - I tap the Setups button - I then tap the name for setup "B." - I tap SAVE. Luckily, the mixer (properly) just saves the current setup back to setup "A." and doesn't destroy setup "B." This is a confusing user interface, completely at odds with every computer interface for load/save. One should NEVER be allowed to select another file (tap another setup name) without first indicating an intention to LOAD something. (Note that a good idea would be to dim-out all other setup names except the current loaded one. Only enable the list of available setups when the user taps LOAD.) When one taps LOAD, there should also be a warning of unsaved changes in the current setup. ​This same behavior applies to SCENES as well as setups. Both should be corrected. This has also been submitted to the Line6 Ideascale site. Quote Link to comment Share on other sites More sharing options...
