Flamo Posted October 2, 2014 Share Posted October 2, 2014 Hello I would like to have a channel switch of my ampli for each patch, by sending program change codes on the footswitch F1, F2, F3 and F4 (those which recall the patch) and sending Control Change codes on / off (toggle) buttons F5, F6, F7 and F8 function as a booster and reverb.Also I would like that when the function assigned to the MIDI Control Change it activates the LED turning on. Now I describe the operation that I have followed : I set the MIDI transmit channel on POD equal to that on GLAB. (I try channel 1 and 3) I proceed by assigning F1 pedal the correct code to programm change. (presets of amps that I want on the patch) I proceed by assigning F5 of the pedal the correct code to control change (function booster amplifier) I proceed by assigning the pedal to F8 the correct code to control change (function of reverb on amplifier) I check on the operation by pressing the various footswitch with the ASSIGNwindow open, everything works fine. I press SAVE and exit from mode "MIDI assigment". I check again and everything is ok. Now I repet the procedure for the patch B (with different code program change), I follow the same procedure, and I check.At this point, with POD in view mode I try the patch A, the channel does not change and remains the last used, the one used previously.I check if there are errors in the code but these are correct.Where's the mistake? I need to change some setup of the pod? Thanks Flamo Quote Link to comment Share on other sites More sharing options...
