jbailes Posted June 17, 2013 Share Posted June 17, 2013 Hello, I've got spider IV 75w with the shortboard, line6 monkey on the computer and the edit software. In the event that I have to do a factory reset on the amp for some reason, how do you "back up" all those save, modified, rearranged presets on the edit software? Thank you. Quote Link to comment Share on other sites More sharing options...
Natedog_37 Posted June 17, 2013 Share Posted June 17, 2013 Top right corner in Spider edit there is a save to PC button. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 17, 2013 Share Posted June 17, 2013 You can download the Spider Edit manual at the following page (it's at the bottom in PDF format). http://line6.com/support/docs/DOC-1812 Quote Link to comment Share on other sites More sharing options...
Jimmikatt Posted June 18, 2013 Share Posted June 18, 2013 just save all your files to your pc, and put them in a folder and zip it up. that is what i did for the "just in case". :) Quote Link to comment Share on other sites More sharing options...
RockettCrawford Posted June 20, 2013 Share Posted June 20, 2013 Hook your Shortboard up to your spider iv and hook it up to your computer via a USB cable. Download Spider Edit. Run Spider Edit and let it load up your presets (does it automatically when it comes up). Then click on "File" and click on "Save Bundle." If you have a factory reset or otherwise lose your presets, then hook this all up again and click on "File" and "Load Bundle" and select your file. Then carefully click on "Receive All" and it'll upload your saved presets to your amp. Quote Link to comment Share on other sites More sharing options...
jbailes Posted June 24, 2013 Author Share Posted June 24, 2013 I appreciate it. Quote Link to comment Share on other sites More sharing options...
