Main :: DT50/DT25
DT25 dead. Changed fuse, caught fire.
by stmmitchell on 2013-03-11 09:34:34.6800
Turned on my DT25 combo yesterday and it died completely a fraction of a second later. No lights, no sound, no glow from tubes. Nothing. My pedalboard on the same power strip works normally. I removed the backcover to check the tubes, they looked fine. Checked the fuse above the powercord inlet which also appeared fine. Tried a new powercord, nothing. It was simply stone cold dead.
Today I found the fuse in the powercord inlet and it was blown. Yay! I jump in my car to get a set of new fuses making sure to bring the old one and the little plastic cover holding it in place. The plastic cover says 1.6w/10A max, so I get a set of slow blow 1A, 2.5A, 5A and 10A. (They come in sets at my local dealer). So I get home and try with one of the 1A fuses, same thing; it turns on then immediately dies. I figure I was unlucky with the fuse so I try another 1A, same thing. Then I decide to try one of the 2.5 fuses. "Whooooosh": the fucking amp catches fire, and blows out a cloud of black smoke ! What the fuck is going on ?!?
Re: DT25 dead. Changed fuse, caught fire.
by TheRealZap on 2013-03-11 10:13:30.0410
fuses dying, are usually an indication that something else is wrong...
is certainly worth a try to replace....
i'd take it to a service center especially now, since it appears to be getting dangerous.
http://line6.com/service_centers/">http://line6.com/service_centers/">http://line6.com/service_centers/
by PDKTDK on 2013-03-11 11:27:08.1470
Welcome to my world!
That's exactly what happened to me. Well, I didn't try different fuses and catch fire.
Take it in.
by Line6Tony on 2013-03-11 12:15:30.6340
stmmitchell and PDKTDK. We're sorry to see this happen to your amps. Please heed Zap's advice and get your amp to a service center right away. We do not suggest you try to repair the amp yourselves, even if you believe the issue is only a fuse. If you don't have one in that list that you are comforatble working with, please contact us for an RMA by calling 818-575-3600, options 3...3...2. Alternatively, you can request an RMA at this form: http://line6.com/company/contact/rmarequest/">http://line6.com/company/contact/rmarequest/">http://line6.com/company/contact/rmarequest/.
by whiteop on 2013-03-12 08:25:33.4080
Welcome to the Blown Power Transformer Club (most likely). Line 6 please resolve this. We love your amp. We love your service. But it's hard to love when it's dead...; )
http://line6.com/support/thread/91445?tstart=0">http://line6.com/support/thread/91445?tstart=0">http://line6.com/support/thread/91445?tstart=0
by spaceatl on 2013-03-12 08:54:28.0270
Next time, read the silk-screened text next to the power jack that tells you exactly what fuse to use....You put an overrated (2.5A) fuse in your amp...The amp had a problem and the fuse was not rated to protect the amp...That is why it smoked...
If you are on 120VAC, 2A fuse is the correct fuse...This is printed on the back of the amplifer and in the manual also...DT25 head and combo use the same power fuse.
DT-25 IEC Power Fuse
100-120VAC - T2.0AL/250V SLO BLO
220-240VAC - T1.0AL/250V SLO BLO
http://line6.com/data/6/0a06434d90db507efbe5b36b9/application/pdf/DT25%20Quick%20Start%20Guide%20-%20English%20(%20Rev%20C%20).pdf">http://line6.com/data/6/0a06434d90db507efbe5b36b9/application/pdf/DT25%20Quick%20Start%20Guide%20-%20English%20(%20Rev%20C%20).pdf">http://line6.com/data/6/0a06434d90db507efbe5b36b9/application/pdf/DT25%20Quick%20Start%20Guide%20-%20English%20(%20Rev%20C%20).pdf
by stmmitchell on 2013-03-12 10:46:47.4990
I´m taking the amp to my dealer sometime this week. Hopefully they can sort it out. As mentioned in my original post I tried with two 1A slow blow fuses. That only resulted in the same behaviour as when it first died, i.e it instantly dies killing the fuse. The little plastic cover which holds the actual fuse also clearly states "max 10A". Pretty confusing.
by TheRealZap on 2013-03-12 11:34:48.0890
that's just the max fuse that the holder recommends for heat...
most likely this same holder is used on many different electronics.
not what the amp recommends...
probably is misleading... but shouldn't been anywhere close to a 10A in there!
what determines the fuse needed is the electronics behind the fuse really...
by boblaw on 2013-03-12 20:19:20.4550
Wow. Should someone from Line6 chime in and tell us these things will not burn our houses down?
by TheRealZap on 2013-03-12 20:35:28.4870
Line6Tony did reply above....
and this is typically a user forum... meaning line6 don't come here regularly....
if you have concerns, call the number that Tony provided above and speak to them directly.
this user appears to have accidentally tried a fuse that was out of spec...
certainly not saying that his amp didn't have other issues...
if you don't deal with electronics frequently, by all means seek out a qualified service center.
by boblaw on 2013-03-12 21:12:28.9110
Yeah, thanks zap, you are on it.  I gotta say I have been overwhelmingly pleased with line6 stuff.  Cutting edge always has teething pains.  Every electrical gizmo has some chance of peril.  I have not had any problems.  This seems isolated (?).
