Main :: Spider Jam
My Line 6 Spider Jam is not recognizing SD Cards?
by FogSmoke on 2013-03-12 15:33:04.9420
I purchased and formatted a 2GB SD Card and inserted into my Line 6 Spider Jam Amp but neither the SD icon in the song menu nor Format SD Card is showing under the save menu?  I am therefore unable to transfer any recordings to my PC or update the amps Firmware to 2.09, I also inserted an unformatted SD Card into the amp and am not able to format it due to the missing menu item, the display does show SD Card In when I insert it and SD Card out when I remove it.  Anyone else experience this problem and / or have any suggestiones it would be greatly appreciated.
Re: My Line 6 Spider Jam is not recognizing SD Cards?
by hd_sali on 2013-03-14 09:43:14.6890
I have the same problem somehow!
I can format my SD card by Spider Jam! but when I navigate into the SD card menu to brows the SD card , or when I want to transfer into/from SD Card, suddenly the spider Jam get restarted! ( Spider Jam intro. appears in the display, like when the Amp powered on!)
I used 1Gb SD Card with FAT16
