Using KB37 (as midi controller only) in conjunction with Balance in Reason 6.5
by MrFigg on 2013-03-14 07:31:08.1770
I currently own a Line 6 KB37. I am about to buy Propellerhead Balance. Can I use my KB37 as my midi controller in Reason but use the Balance as the recording interface. In this case will I still have the extra model packs available which come with the KB37. Would really appreciate it if someone could help me out with this. Thanks in advance.
Cam
Re: Using KB37 (as midi controller only) in conjunction with Balance in Reason 6.5
by Triryche on 2013-03-14 09:23:32.5210
You should be able to use the KB37 as a midi controller.
What I'm not 100% sure about is the model packs.
Technically if the computer can see the KB37 via USB you will have access to the model packs, but the plug-ins only, not standalone.
by MrFigg on 2013-03-14 09:39:17.8210
Thanks for the reply. The computer can see the KB37 as I've been using it as my main audio interface up to now. I'm not bothered at all about using Pod Farm so as long as the models are available in Reason and I can use the keyboard to control the midi then I'm happy. Would really like to get this confirmed 100% though...maybe some Line 6 staff know the answer? In any case thankyou for your reply.
Cam
by Triryche on 2013-03-14 10:47:24.1510
You can contact Line6 directly by phone or support ticket, they rarely monitor the forums ever since they changed there support approach.
http://line6.com/company/contact/">http://line6.com/company/contact/">http://line6.com/company/contact/
I'll see if I can another set of eyes on this in the meantime.
by MrFigg on 2013-03-14 10:48:50.0820
Thanks a lot. Much appreciated. I'll keep looking in to see if you came up with anything. Think they've probably gone home for today.
Cam
by Line6Tony on 2013-03-25 10:24:20.5710
Hi. You will have the option to choose between any devices connected as the MIDI controller and the audio interface, so you can use the KB37 and Balance together. The model packs will be available as long as the KB37 is connected.
