Main :: POD HD
Looper tone suck?
by grandma on 2013-03-15 06:24:46.9100
I'm using the HD500, and I've noticed that when the looper is in the "pre" position, the loop I create sounds exactly like the patch I am using, but when it is in the "post" position, the looped recording sounds thinner and slightly different. Has anyone else noticed a difference in the recording quality between "pre" and "post" in the looper?
Re: Looper tone suck?
by hurghanico on 2013-03-15 07:23:03.3150
1) the looper fx output is mono, your patch probably is stereo, therefore is normal to have some sound difference when it's in post position..
2) if your looper is set on half speed (to get double avaible loop time) the looper output sound quality is lower than that in full speed
by silverhead on 2013-03-15 07:26:29.9560
Check your Looper settings - there are HiCut and LoCut controls that will affect the tone.
by grandma on 2013-03-15 10:08:42.1160
Thanks, guys. That explains what is happening. I will check it out later today.
