Main :: POD X3
Loud noise
by Noah_Paradise on 2013-03-16 11:56:42.1100
I found out how to record using the digital audio interface built into the POD x3 live, which is good. I'm recording with "Audacity". And when I record a track, it records perfectly okay, no problem. But when I go to record a second track, I get a loud hissing noise. It sounds like what I can only describe as white noise, only with more treble.
Re: Loud noise
by Triryche on 2013-03-20 09:01:06.1850
Well if all the settings are the same it is probably because Audacity does not support ASIO.
Also make sure you are not "reamping" the first track.
I would get a DAW that supports ASIO, Reaper is free to try and goes for only $60.
Or you can try to compile Audacity with ASIO
http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface">http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface">http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface
