Main :: Flextone I / II / III / Duoverb / HD147
Flextone III Plus - 100 or 150 Watts - Which one do I have?
by mortn on 2009-06-24 06:41:50.2460
Hey guys,
I just bought a used Flex III Plus which seems pretty new but is there any way to tell (revision index, serial number?) if I have the 100 or 150 watt version?
There's no direct indication of the amps wattage on the back panel but I know you guys are smart.
Cheerio
mortn
Re: Flextone III Plus - 100 or 150 Watts - Which one do I have?
by geodavjenk on 2009-06-24 09:06:23.4180
If you have the Plus it is 75 watts per side stereo for a total of 150 watts. But that also dependents on which literature you read. Some say it is 60 watts per side for a total of 120 watts and there have been tests run by some of the forum users verifying the FlexIII+ and XL are 120 watts. You can tell you have a plus by looking at the back of the amp. There should be effects send and returns for both left and right channels and speaker outputs for left and right channels. The plus and XL are the same amp but the plus is installed in a 1x12 cab while the xl is installed in a 2x12 cab.
Hope this helps
DaveJ
by mortn on 2009-06-24 10:51:00.3900
Hi DaveJ,
thx for your reply. Maybe my initial post was a bit confusing (not a native speaker ). I definitely have the Flex III Plus. AFAIK, there has been a power amp upgrade for the whole Flextone line back in 200x. Line 6 didn't change the amp's cosmetics so there is no obvious (at least not for me) way to tell what power amp is working inside. I think the old Flextone III Plus series had 60/100 watts and the updated one has 75/150. I consider the new power amp a significant upgrade so I'd really like to know if there's a way to tell them apart.
Thx again and more replies are welcome!
by ChaChing on 2009-06-24 11:45:33.4640
Are you maybe comparing a Flextone III Plus to a Flextone II Plus? Those have similar specs in terms of the difference you describe, but per our documentation / older employees there was no design change to the Flextone III Plus...so as long as you have a III plus, then you have the 75/150.
Thanks
Line6Sach
by mortn on 2009-06-24 13:06:09.3030
Hey, straight from the horse's mouth. I was refering to the III (3) series only as the Flextone II series wouldn't be too hard to tell apart from the III series.
I'd swear I can remember reading something about a Flex III power amp update (along with the software 1.1 update) back in 2005 when I was shopping for an amp and browsing the L6 page. I just quickly searched the web and found this old announcement from 2003:
http://www.wholenote.com/news/item.asp?i=528
Many retailers (especially here in Germany) still seem to spec the Flextone III series with 60/100 watts.
Moreover, the official manual specs the Flextone III Plus as a 100 watt amp (page 17).
I would suspect retailers ond blogs to be capable of a lot of confusion but I can't imagine Line 6 accidentally writing the Flex II specs into the Flex III manual as the new power amp would be too much of an upgrade to be overlooked.
I hope I'm not to persistent and make some sense.
One more thing: Is there a way to determine the amp's build date with the help of the serial number?
by geodavjenk on 2009-06-24 13:24:29.0370
mortin, thats basicly what I was referring to in my post. There was a lot of confusion and misinformation on the Flextone III series. There were posts ans advertisements going around saying the FlexIII+/XL was 60/100, 60/120, and 75/150. The official L6 stance has been that it is 75/100 as mentioned above. We have had users from the forum that are in the electronics that have run tests on actual FlexIII+/XL and found that they are probably closer to 60/120. I've been a FlexIII owner for quite a while and can't remember an upgrade in the power amp, just the misquoted specs. Either way I like the FlexIII+/XL and it's plenty powerful enough for any gigs I've done and I play everything from small venues to large outdoor festivals.
DaveJ
by mortn on 2009-06-24 13:44:11.0660
Thank you for clearing things up for me. I think I'm feeling less confused now.
The question is officially answered but If anybody knows something about the serial numbers...
by mortn on 2009-06-24 14:50:25.0100
Guess, I've found the answer:
"The Flextone III series was released in 2003.  Line 6 does not make serial number identification public knowledge, ..." Line6Andy
by JohnnyBGreat on 2012-11-18 20:28:20.8900
why not? I would like to know everything I can about this fabulous amplifier.
