Main :: StageScape M20d Mixer Community Support
How do I play music from the computer through the StageScape?
by Nicolazy on 2013-03-21 08:08:20
I have already installed and configured drivers audio output mixer to go out, but do not hear, nor see an indicator.
Sorry for my English, I'm using a machine translator.
Thank you!
Re: How do I play music from the computer through the StageScape?
by ArneLine6 on 2013-03-21 09:14:58
The USB audio from the computer is routed to the M20d's inputs 17/18. Just put the laptop preset on stage. The laptop preset defaults to input 17/18.
by kmachman on 2013-03-21 09:27:55
If you are looking to record while using that route, you cannot record to the SD card while USB is plugged in.
I found that having a 1/8" phono line out from my computer to 2 stereo inputs to the line in's on the M20D is better if you wish to record the music and all the tracks together.
Thats the way I found to work the best.  Then the volume control will also work in your computer.
I have an iMac.  Not sure about PC's.
by Nicolazy on 2013-03-22 10:29:26
I wonder if through the firewire cable I can play music (no matter if I have to assign a channel for it or not) Thanks!!
by unyun on 2013-03-22 16:12:59
Add the laptop icon to your stage from the Setup tab.   Laptop will appear in the toolbar, use the hardware knobs to turn up the gain.
by Nicolazy on 2013-03-22 17:21:14
Thank you all for answering forum! easy was what I wanted to do but could not do it. Thank you again. This forum is very useful!
