Main :: POD HD
Volume Control using Expression Pedal - Pod HD300
by the29band on 2013-03-22 06:41:34.2000
Hey guys,
I recently bought the Pod HD300. Moving from one preset to another, sometimes, the volume changes drastically especially if I'm going from a clean to a high-gain preset. I use the expression pedal to turn up or down the volume in this case, however, I have realized that the changes in volume are not very gradual. I have calibrated the pedal but most of the times, when adjusting volume, it suddenly goes from nothing to very high and vice versa, even if I am moving the pdeal softly. Since I have been playing using headphones, this concerns me even more. Is there a way around it? Is there a knob I can use (which is more responsive) than the pedal to control this? I see there is a master volume on the back but changing that all the time with each preset is not going to be easy, since it's on the back. What about channel volume knob?
Thanks in advance for your help!
Puneet
Re: Volume Control using Expression Pedal - Pod HD300
by Mr_Arkadin on 2013-03-22 06:43:22.2730
You should resave the presets with the volumes matched using channel volume.
by the29band on 2013-03-22 06:44:56.9020
Ah, okay! That makes sense. Thanks for your answer.
