asio problems with windows 7
by foofighterux2 on 2013-03-23 06:16:56.9290
this is nuts ive got a dell duelcore 64 bit 4 gb ram pc 2.70ghz.reinstalled drivers 3 times now and when im in the middle of doing stuff the sound cuts out.i take usb out but it still shows up in sounds (windows 7).i reboot then it says fatal errors.never had this with xp sp3/ever.please can i get help?thank you.also sometimes i put usb lead in and the toneport ux2 clip lights flash and it wont connect.what is asio4all?not sure if that will work.cheers chris.
Re: asio problems with windows 7
by Triryche on 2013-03-23 10:48:16.7800
Just to confirm, if you run Monkey you have green ticks for drivers and firmware.
Also check drivers for your chipsets for your Dell and try different USB ports.
Check out this guide for USB issuees
http://line6.com/support/docs/DOC-4282">http://line6.com/support/docs/DOC-4282">http://line6.com/support/docs/DOC-4282
If you still have problems contact Line6 directly via a support ticket or phone:
http://line6.com/support/tickets/add.html
Line 6 - North America
Line 6, Inc.
26580  Agoura Road
Calabasas, CA 91302-1921
Main Phone#: (818) 575-3600
Main Fax#: (818) 575-3601
Customer Service hours are 8am - 5pm M-F Pacific Time
Press option 3 for Customer Service
Our busiest hours are from 11am to 2 pm.
Line 6 - Europe
Line 6, Inc.
The POD
Clifton House
Butler's Leap
Rugby, Warwickshire
United Kingdom, CV21 3RQ
Telefone: +44 (0) 1788 566 566
Fax: +44 (0) 1788 566 529
Technical Support: +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT
