Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
how do I reset to factory presets
by kerapoo on 2009-07-30 16:37:33
how do I reset to factory presets???
Pod xt Live unit
I just sold it..
Do I need to unregister it???
Re: how do I reset to factory presets
by AndyParedes on 2009-07-30 16:47:26
Hello,
Here is the factory reset procedure for the XT series:
Please go the following link to download/install the latest Monkey software for your Operating System.
http://line6.com/software/
Copy/pastethe following links into your internet browser for additional Line 6 software information:
Line 6 Monkey Installation and F.A.Q.
http://line6.com/community/docs/DOC-3898
InstallingDrivers For Your Line 6 Device
http://line6.com/community/docs/DOC-4427
Podxt Series: Factory Reset, Reflash, and Firmware Updates
http://line6.com/community/docs/DOC-3827
Ihave already removed the unit from your account for your buyer.
by jo6pak on 2009-07-31 04:57:30
If I may ask, then, what is the purpose of the "Complete Factory Recall" procedure on page 4-14 of the Bass PODxt manual?
by jo6pak on 2009-08-01 09:39:34
Still waiting for an answer...
by LoonyBin-Fizzbin on 2009-08-01 11:34:02
The Bass Pod XT series has a different reset procedure than that of the (Guitar) Pod XT series of pods. this change occured in one of the Flash Memory updates, to allow the use of model packs!  Here are the current Factory reset procedures for Line 6 Gear!
Factory Reset Procedures
VERSION 8
Created on: Jun 4, 2007 9:37 AM by Line6Andy - Last Modified:  Jun 24, 2009 10:43 AM by Line6Hugo
Note: This will erase all current presets and restore the factory sounds, so please save your sounds on a second source if necessary.
Axsys 212 or AX2: Press and hold the "User/Preset" and "Save/Store Sounds" buttons, and keep holding as you turn the unit on.
Duoverb: Hold A & D while powering unit.
Flextone I &II: hold down A, B, C, and D while powering the unit on.
Flextone III:  hold the A and D Buttons while powering up for 8 seconds.
Bass POD: press and hold the up and down arrow buttons as you power the unit on for ~ 5-7 seconds or until it goes to the preset 1-A
Bass POD Pro: Hold the UP and DOWN arrow key down as you power on for ~ 7 seconds.
Bass POD XT Pro and Bean: press SAVE once, use the select key to scroll clockwise to “factory recall” page, then press SAVE twice.
Bass POD XT Live: see POD XT Bean/Live/Pro
Floor POD: Hold MOD and DELAY while powering up.  When “01” appears, disconnect power.  Power up.
Bass Floor POD: Hold COMP and FX while powering up.  When “01” appears, disconnect power.  Power up.
Floor POD Plus: Hold BANK UP and BANK DOWN while powering up unit (display will read INT)
Four Button Modeling Pedal: (DL-4, MM-4, FM-4, DM-4): Hold  A and D footswitches and power up - the power is turned on and off on the modeler pedals by inserting a plug into the left mono input jack.
HD147: hold the A and D Buttons while powering up your amp.
JM4: Hold down the settings/tone button as you power the unit on and hold the button for 5-8 seconds.
M13: Press and hold Looper Controls to enter the setup menu.  In FX UNIT 4, turn the Model Select knob until the corresponding display shows RST FACT.  Press down on the Model Select knob twice to complete the reset.
Lowdown: power on while holding down the 'A' button for 5-8 seconds.
POD/POD 2.0/Bass POD/POD Pro: press and hold the up and down arrow buttons as you power the unit on for ~ 5-7 seconds or until it goes to the preset 1-A
Pocket POD: Hold the save button and 4-way arrow key up while plugging a cable into the instrument input to power the unit on.  The unit will prompt for a factory reset, press save to initiate the factory reset.
POD X3 - Bean/Live: Press and hold the ‘Home/Hold For Commands’ button, select ‘Reset User Presets’ and press the ‘Save’ knob to reset the User bank to its factory presets.
POD XT: Bean/Live/Pro:
Attached Below as a PDF file.
Rackmounted Pro Effect units
MOD Pro/Filter Pro/Echo Pro: press MIDI/Sys, use program select knob to “FR” (save button will begin flashing). Turn speed knob all the way up to “all”, press save twice.
Spider I, II, III, Micro, and Valve Series: Hold down the A (or clean) button as you turn on the power and hold the button for 5-8 seconds.
Spider Jam: Hold down the settings/tone button as you turn on the power and hold the button for 5-8 seconds.
VARIAX Electric and Acoustic Guitars and Basses
You will have to connect your VARIAX to the WORKBENCH, POD XT/X3 LIVE, or VETTA II to reset your factory default settings. Then you will have to connect your interface to your computer. Here are the instructions for each:
Variax Electric 300, 500, 600, 700
  These instruments can only be returned to factory reset by reinstalling the flash memory.   Connect the Variax digital guitar cable to your Variax interface (you will need to have the unit powered the with TRS cable unless you are using a POD XT/X3 Live or Vetta) to the Line 6 Monkey, select your variax instrument, choose firmware (in the updates tab), and select “reinstall latest”.
Variax Acoustic (Steel String and Nylon) 300
  These instruments do not have a reset function.  The presets are simply a variety of settings that the user can overwrite. In other words, the user cannot lose anything, except for the original settings that are provided as examples/starting points.
Variax Acoustic 700 - Soft Reset
  Start with unit off (TRS cable and/or Variax Digital cable unplugged from guitar). Rotate the model selector to the SITAR position.
  Press and hold model selector (as in Save routine) while inserting TRS cable or Variax Digital cable to power up the unit and perform reset.  For a full reset, please follow the Variax Electric Guitar procedure as described above.
Variax Bass 700 705
  Factory defaults must be restored one at a time. Select the Model you wish to normalize. Place the blend and two tone controls in the detent position. Now press the Model select pot down until the indicator light stops flashing. The Model should now be restored to factory settings. Use this procedure for any model you want to restore to the factory setting.
Vetta I & II
Soft Reset:
Hard reset:
Vetta Reflash procedures
Thank You Tech Guys
by pwoods27 on 2009-09-08 11:11:56
Just wanted to say thanks for helping me restore my Factory Prestes on my Pod XT live.....
Perry Woods
myspace.com/theperrywoodsexperiencePerry Woods WXP (29).jpg
by blaydenz on 2010-08-17 04:23:05
What if my PODXT cannot save any changes...My save button does not work....is there something I can do through the gear box?   My email is mike.vcfe@gmail.com
Thanks
Mike
