Main :: StageScape M20d Mixer Community Support
Do I need a DI Box?
by tochiro on 2013-03-29 01:08:49.8270
I plan to buy an LR Baggs M80 for my acoustic guitar (it can be set to active or passive mode).  Do I need a DI Box to connect to the StageScape?  If so, should it be active or passive?
I play about 2 meters away from the StageScape.
Thank you for your comments.
Cheers
Re: Do I need a DI Box?
by antonioctd on 2013-04-13 02:55:31.1990
In active mode you should be ok with just a guitar cable.
It's not ideal but I got away wih it a lot of times already...
Just try it and if it works, great.
If you get muffled sound or you have to push the pre-amp to hard and get loud noise floor, you need a DI.
For acoustic guitar I seriusly recoment something like this:
http://www.bbesound.com/products/instrument-preamps/acoustimax.aspx
You'll love the mute footswitch (for tunning) and the extra rotting functionality for tuners, fx, etc...
by litesnsirens on 2013-04-13 10:01:30.7370
I don't think you'll need a DI.  The M20d in my experience so far has a pretty wide range of trim, I think you'll probably be able to use in either passive or active, you'll just have to adjust your trim accordingly.
by ArneLine6 on 2013-04-14 11:28:10.0550
Depending on the exact impedance of the guitar output it is usually no problem to plug in straight to the mixer. As Antonio mentioned- just try it.
