Main :: POD HD
FBV MKII "hold for tuner" button doesn't work when using FS 5-8.
by NeedmoreCrunch on 2013-04-06 11:53:48.9070
The button is assigned the "FS 5" footswitch position.  Even after switching back to ABCD it still doesn't work.  Is there a fix for this?
Re: FBV MKII "hold for tuner" button doesn't work when using FS 5-8.
by silverhead on 2013-04-07 07:27:05.1340
I recall this being mentioned in the past with the Pod HD Desktop/Pro, but I think it was fixed in the latest firmware update. Is your device firmware  up to date?
by NeedmoreCrunch on 2013-04-07 09:54:03.5600
Yup, firmware is up to date.  I just found the culprit.
In the setup menu, when switching the FBV Express option to "on" the "hold for tuner" option is disabled.  I just tested this and found it is not related to the FS 5-8, or ABCD.  It is only when the FBV Express option is set to "off" that the "hold for tuner" switch operates normally.
