Main :: POD X3
Asio4all displays me red exclamation sometimes when I record with my pod x3 live
by HW_Blue on 2013-04-08 08:41:26.7370
Hi everybody
I've got the latest drivers of my pod and of asi4all, but when I record Asio keeps displaying me red exclamation dot and it stops the recording for a few secs, very annoying.
I record with Cubase LE5, pod plugged with USB on my laptop
I'm on w7 64 bits, with 4G of RAM on a laptot. A few months ago, I hadn't this problem... Can anybody help ?
Thanks !
Re: Asio4all displays me red exclamation sometimes when I record with my pod x3 live
by silverhead on 2013-04-08 09:11:43.3370
ASIO4ALL is not a compliant ASIO driver. Its use is not supported with Line 6 products. You should use the Line 6 ASIO driver provided with your X3 Live.
Configure Cubase to use the X3L and its ASIO driver as the audio device. Connect your speakers/headphones to the X3L outputs.
by HW_Blue on 2013-04-08 10:45:37.1680
Is there any tuto on how to confifure it properly, or can you explain me in a few words if its not too much.. ?
Thanks thousand times for tour answer !
by silverhead on 2013-04-08 11:37:20.0780
Sorry - I don't use Cubase  so can't help you with the specific menus/settings. In general any DAW has a menu/panel to configure your audio system. Look for it and set it to use the X3L and its ASIO driver as the audio device.
by HW_Blue on 2013-04-08 12:13:54.1690
Thanks, I'll keep you aware !
