Main :: POD HD
Need Suggestion - Pod HD500 with Blackstar HT DistX
by pratikb on 2013-04-09 11:52:40.2550
Hello All,
I have recently bought the Blackstar HT DistX to go along with the POD HD 500.. Please advise if i should use it as per the below signal chain
Guitar>>>Crybaby>>>Blackstar HT DistX>>>Pod HD500>>>PA (NO AMP)
or if there is any other way i can connect the Blackstar HT DistX.
Thanks in advance
Pratik
Re: Need Suggestion - Pod HD500 with Blackstar HT DistX
by phil_m on 2013-04-09 12:05:25.1770
Certainly nothing wrong with doing it like that. If you wanted a little more flexibility in your signal chain, you could always try putting the Blackstar pedal in the HD500's loop.
by pratikb on 2013-04-09 16:35:38.1680
Thanks Phil_m for your reply.... but how to have it in the pod's effects loop?
