Main :: FBV MkI / MkII Controllers
FBV mk2 volume controlling via 75 watt spider 4
by jak_E_lee on 2013-04-14 17:20:53.4320
i have had this amp almost 2 years
have read the manuall and followed the steps i believe to be correct
I created a patch of my own,stored it in a bank,however its giving 100% volume with the pedal ful forward but full back i want the volume to 0% but i would say full back its pulling the volume back to around 40%.
Tried....yes..i have tried to correct this via the edit but to no avail!
Anyone know how to tweak this so i get 100% forward and 0% pulled back on the pedal?
Re: FBV mk2 volume controlling via 75 watt spider 4
by fflbrgst on 2013-04-15 05:37:12.9840
You need to set the volume pedal range in the patch you created.  Page 3-3 of the manual details how to do it.  Sounds like you have the Min setting at something other than 0%.
by jak_E_lee on 2013-04-17 17:18:24.0750
it has actually turned out to be,my fbv mk2 pedal was not calibrated correctly
there is a procedure to re-calibrate pedals
followed out the set up calibration instructions and its fine now
