Main :: M5 / M9 / M13
M5 Usage Question
by negativefx on 2013-04-19 17:24:16
Howdy,
Looking to get an M5 for my bass board.  Pilot's Guide isn't particularly clear on how the INSTANT PRESET function works.  If I enable that setting, how do I turn the pedal on and off?  Tap both buttons?
Also, has there ever been a firmware update for the M5 or is the latest still v1.00?
Cheers!
Re: M5 Usage Question
by phil_m on 2013-04-22 06:54:03
I no longer have an M5, but I believe if you tap both buttons, it takes you into the preset, and then you can turn the effect off. The other thing you can do is make a preset with the effect turned off when you save it. So you can create a bypass preset. Although, in Instant Preset mode, this might not be too helpful because as soon as you scroll to a new preset it loads.
Regarding the firmware, there's not been any update past the original release.
by negativefx on 2013-04-22 12:09:16
Ok thanks phil.  Helpful as always!
