Main :: Variax Guitars / Bass / Workbench
Variax Presets
by roadh on 2009-08-28 12:15:40.9370
Is there a simply way to restore the factory presets to my Variax 600 guitar?
Re: Variax Presets
by amx05462 on 2009-08-28 12:35:56.0700
yes reload  the  origonal firmware.
Re: Variax Presets
by Line6Hugo on 2009-08-31 10:56:52.8350
+1 to amx05462
You will have to connect your VARIAX to the WORKBENCH, POD XT/X3 LIVE, or VETTA II to reset your factory default settings. Then you will have to connect your interface to your computer. Here are the instructions for each:
Variax Electric 300, 500, 600, 700
These instruments can only be returned to factory reset by reinstalling the flash memory. Connect the Variax digital guitar cable to your Variax interface (you will need to have the unit powered the with TRS cable unless you are using a POD XT/X3 Live or Vetta) to the Line 6 Monkey, select your variax instrument, choose firmware (in the updates tab), and select “reinstall latest”.
Regards,
Line6Hugo
Please make sure to award points to helpful & correct responses to your questions.
Re: Variax Presets
by roadh on 2009-09-01 00:02:36.1450
Thanks for the help, I restored the defaults using Line 6 Monkey without any problems
Re: Variax Presets
by grbrum on 2009-10-17 13:32:43.0110
Hello, how do I select my variax in the Line 6 Monkey?
I hit the Change Device button but I can`t access the guitar.
I am on OSX Leopard, L6Monkey version 1.31.00
I am connecting it via a pod XT live with firmware version 3.01 and USB firmware version 1.12
thank you
