Main :: Line 6 X2 Digital Wireless
XDS Plus not receiving
by ibaker on 2009-09-21 11:43:27.9240
Had the unit almost a year, I don't use it at practice, and it has been used for maybe 12-15 shows (a total of about 8hours). I turned it on at my last show the receiver's blue light goes back and forth, the transmitter was powered on and blinking its designated channel. The channel matched on both units but it never showed any signal. Changed channels, powered on/off, unplugged/replugged power, removed and reseated antennas, still the same result everytime.
Re: XDS Plus not receiving
by dboomer on 2009-09-22 10:35:35.7670
Did it work properly and then just start failing to communicate?
by ibaker on 2009-09-22 13:10:05.5890
It worked perfectly everytime I used it until the last time. The problems I described all showed up at the same time which was the last time I turned on the unit.
by dboomer on 2009-09-22 15:19:11.1630
Double check that both units are operating in the same mode.  Do you know how to check?
by ibaker on 2009-09-23 12:08:16.4480
No I don't, and why would one of them change modes on its own after just being in the box for 2 months?
by dboomer on 2009-09-23 13:51:44.9750
Well it doesn't change by itself ... but it is changed by holding the channel button in while pressing the power up button.  It's easy enough to do by accident.
In XDS-plus/XDR95/ Q-diversity Plus mode the lights turn all blue and then a single red lED scrolls back and forth across.
In regular mode the lights turn they turn blue and then a red comes on in the middle followed by 2 outside that and then 2 more outside that.
The receiver tells you by itself so it's pretty straight forward.  They must match up.
So I always forget to ask ... you are using this in North America and you are using the factory supplied power supply ... correct?
by ibaker on 2009-09-24 08:40:22.4520
Yes, It is all exactly how I bought it, and yes it is being used in the states. As for the lights, I will check that again at my next opportunity but as of last night it was the same. The signal light traces back and forth, blue, looking for a signal.
by ricksox on 2009-09-24 11:33:13.3800
You could have a hardware issue. Did you purchase the unit new? If so, then you should still be under warranty. You should give us a call directly so we can arrange a repair for you.
(818)575-3600
Line6Miller
by ibaker on 2009-09-24 11:40:01.5150
Brand new from Guitar Center. Still keep it in the box. I'm pretty sure I didn't register it, but I can produce a receipt of purchase. Am I still going to be under warranty?
by dboomer on 2009-09-24 13:26:55.3490
2 year warranty with your receipt.
by ricksox on 2009-09-24 15:06:47.7690
Yes. Please call us so we can arrange a warranty repair for you. Thanks.
Line6Miller
by bebesito on 2009-10-06 13:23:50.7970
Sorry but I've the same problem.
After reading your answer, I've checked  the units.
I'm able to change the transmitter mode (regular or not)
But not in the reciver where the lights turn they turn blue and then a red comes on in the middle followed by 2 outside that and then 2 more outside that.
Even changing the transmitter in the regular mode, the reciver still doesn't link it.
by dboomer on 2009-10-06 15:39:08.1190
Yes ... I see in your other post that you live abroad.  XDS only works in North America.  is that where you are trying to use it?
by bebesito on 2009-10-07 04:53:17.4860
Hi
Thanks for answer me!
I'm living in Argentina (Italian Embassy).
But, why it works only in North America?
And if it so, why the seller didn't tell me?
BTW, I tried to test it in the hotel. And, even there it didn't work.
Unforunately, I thought it was my fault and that I had to read with more attention the instruction.
If I send it back to the seller, does he have to change it?
Once again thanks for your help and have a great day.  ;-)
by dboomer on 2009-10-07 17:00:48.5830
Pardon me ... I gave you the wrong info.  I checked with ITU and X2 is cleared for use in South America as well.
Let me ask two questions ...
Did it ever work and has stopped working?
Are 900 mHz cell phones permitted in your area?
by bebesito on 2009-10-08 05:11:21.9450
Hi Dboomer
Thank a lot for your time.
  1. No, my XDS95 has never worked. Even when I try to test it in the Hotel in Orlando, both XDR1 and XDT1 power up, but they couldn't link each other. As I told you I thought it was not a problem and that I had to read more carefully the instruction.
  2. As long as I can see, only GSM-1900 GSM-850 should work in Argentina.
All the best
Fabio
by dboomer on 2009-10-08 13:56:32.7600
You may have a hardware problem.  Return it to the dealer or call service 818.575.3600
by palmerize on 2010-07-25 09:30:15.7480
Just wanted to thank you for your solution to this problem. Bad lighting must have caused me to accidently push the button ... it was in the XDS mode instead of XDS Plus.
Thanks,
Glenn
by dboomer on 2010-07-26 10:46:35.3900
Don't ya just love happy endings
