Main :: Vyzex Editor
Firmware-Update
by JeremyDixon on 2009-11-23 10:57:49.5070
I know, this is a VYZEX-Forum, but I've just another question.
I updated my pocket-pod from 1.00 to 1.01, but I don't understand what is it good for?
Can I use new functions or is it possible to change the cabinets without using VYZEX-Software?
And how do I have to operate?
Thanks for information.
Regs
Jerry :-)
RE: Firmware-Update
by ricksox on 2009-11-24 11:53:05.6430
Hello,
The Pocket POD firmware update fixed a couple of known bugs in the firmware.
This firmware update fixes a bug related to Cabinet Tuning mode as well as one related to the saving of Delay Time per patch .
Has this answered your question?
Line6Miller
Re: RE: Firmware-Update
by JeremyDixon on 2009-11-25 01:13:16.9640
Hello,
thanks for your reply.
But I'd like to have more details please.
I thought until now, the pod works fine and can't find any bugs.
Especially I'm interestet in the bug relating to the
cabinet tuning - which problem was solved?
Thanks.
Jerry
PS: why is it so difficult, to get detailed informations????
by PsicraftTony on 2009-11-25 01:53:59.4760
Hi Jeremy,
What Line6Miller told you is pretty much the only change to the PocketPOD firmware: The v1.00 worked completely fine, but the cabinet tunings were not as good as they could be according to Line 6's exacting standards.
Recall that PocketPOD has a cabinet emulation parameter that affects your guitar tone by simulating a particular amp cabinet: These are important when you are running your POD directly into headphones or a recording input without first sending the sound through an actual guitar amp cabinet and miking it. Bottom line is, in v1.01, these cabinet models sound more accurate to the actual cabinets in question.
For more information on the cabinet tuning parameter, you should download the POD 2.0 advanced guide from the Line 6 documents library - It elaborates even further than I have.
Cheers,
Tony
by JeremyDixon on 2009-11-25 10:33:55.0690
Hi Tony,
thanks for your quick answer.
Now it is clear. (I thought Line6 did a lot of changes and we have new functions...)
Regards
Jeremy
by PsicraftTony on 2009-11-25 11:13:51.4250
No problem. I note from Line6Miller's post that there is also a minor fix to the delay time parameter edit-and-save mechanism in v1.01 - That's kind of a feature... ;-)
Tony
by mondolive1 on 2010-10-26 18:32:12.9450
hey i really need some help. when i try to connect my fbv express shortboard to my computer is say firmware does not meet minimum requirement for device. i installes the line 6 monkey update and it still says it. what can i do?
