Main :: Spider Jam
How do you convert your recorded JAM. files?
by larswik on 2009-11-28 16:37:24.3710
Hi!
I'm a little bit new with "Spider Jam". And I have a question. I have recorded some tracks I realy want to put on my computer. And I've tryed, and tryed, but no luck
I've tryed to save the recording mix as an WAV. to my SD card, but it says: SD-CARD ERROR!
And I've tryed to look for some applications that converts this JAM. files, but again, no luck
I've allso tryed to convert the JAM. file in the name of an WAV. file, but that did'nt work ether
So I wonder:
- Are there maybe an applicaton that can convert JAM. files?
- Am I maybe doing something wrong when I try to save the recording mix as a WAV. file to my SD-Card?
- Or are there somthing else I can do to get my recordings readeble on my computer?
I hope for an answer. And I thank you if you give me an answer.
And I'm sorry if my English is a little bit bad
Re: How do you convert your recorded JAM. files?
by Buy-a-Fender on 2009-11-28 16:42:15.0960
did you format the SD card in the Spider Jam?
See page 2.1 of the Spider Jam Advanced Guide for info on formatting SD cards and how to save recording mix as a WAV file to the SD card
if you do not have a copy of the Spider Jam Advanced Guide you can get it here http://line6.com/support/manuals/
also, you can check out Joe Gillespie's web page
http://www.joesjamblog.com/jam2wav.html
where Joe has developed a utility to convert JAM files to WAV files
by larswik on 2009-11-28 16:51:25.3280
Thank you. I've tryed to format the SD-Card and it worked. Thank you so much. You saved the day
by sss_sharan on 2009-12-05 01:30:05.0860
Nope - no software to do that   - only way to do it is thru the amp
by shadowdoghd on 2012-05-14 05:13:24.3380
could you explain how you done this with sd card.i got the amp used and would like to clear theyre recordings
