Main :: Spider Jam
Shortboard I or II with the Spider Jam
by Shreddingmeat on 2009-11-28 23:25:46
Hello,
I'm a bit confused with the FVB Shortboard (older and newer versions) and the Spider Jam amp.
In the Jam amp operator's manual, it shows pictures and a description of the older shortboard with this amp.  However on the box of the Shortboard, it says that it cannot be used with Spider III series or anything close to the Spider Jam.  I assumed that it could not be used with the Jam so I returned it to the store where I purchased it and brought a MK II instead.  Now, it looks like that I could have used the older version with the Jam amp anyway.
So which shortboard can be used with the Jam amp, the older version or the MK II?
Also for the MKII, what is the exact packaging material inside the box?  I only saw a warranty card, some short literature info, a pilot's guide and a CAT 5 cable.  Is there a power supply adaptor or a full size instruction book that should be inside the box?  I did not see a full version of the operating instructions to download.  Can someone please tell me where I can get it?
What is the MIDI hook up for and how can I get this option with my set up?  Do I have to buy this separately?
Thanks.
Re: Shortboard I or II with the Spider Jam
by daydreamin7677 on 2009-11-29 05:15:42
Either shortboard WILL work. There is no external power supply, the pedal will power up once its plugged into the amp with the CAT 5 cable. The midi function on the MKII will serve no purpose for you. It is for use with the new spider 4 amps.
http://line6.com/support/manuals/?families=11&submit=Submit&1st=1sthref="http://http://http://line6.com/support/manuals/?families=11&submit=Submit&1st=1st
">http://line6.com/support/manuals/?families=11&submit=Submit&1st=1st">http://http://line6.com/support/manuals/?families=11&submit=Submit&1st=1st
by malibustacey on 2009-12-12 14:44:06
does anyone know what the mkII will allow you to do with the spider jam?
RE: Shortboard I or II with the Spider Jam
by ricksox on 2009-12-14 16:21:53
Hello,
Here's some documentation that should answer your questions.
http://line6.com/community/docs/DOC-4629
The Spider Jam works exactly the same way with the MkII as it does with the MkI.
Line6Miller
