Main :: POD Pro
pod pro
by Dsteelman50 on 2009-12-30 11:39:19.1130
I have recently purchased a pod pro and cannot find a way to turn off the amp models as I can on my podxt. Is there a way to enjoy the effects without having to try to get one of those amps to not screw up the sound of my steel guitar? I have read the book from cover to cover and can't find a way.
RE: pod pro
by ricksox on 2010-01-05 10:29:28.1920
Hello,
There is no bypass on the POD Pro. The closest you'll come is setting the Pro to Tube Preamp and dialing in as clean a tone as possible.
Line6Miller
Re: RE: pod pro
by rsegundo on 2011-06-04 21:00:40.3980
So there is no bypass for any of the drive/overdrive & cab options???  I've had my POD Pro for so long and never used it because I can't figure out the damn thing...even
worse there's so little info about this older model.  If there's no bypass option I need to ditch this thing asap because it doesn't compare to my TS9, TS808 and
Doss OD20.
