Main :: GearBox
What is causing Guitarport sound cut outs?
by lsmith4234 on 2010-01-21 07:17:13.7410
The problem that I having is as follows:  When I try to play through Guitarport along with an internal Cd/DVD, my guitar cuts out
intermittently throughout the song.  Guitarport works fine as long as I don't use the internal CD/DVD player. The CD/DVD player works fine as long as I don't use Guitarport.  I have used the Monkey to update all software.  I have assinged Guitarport as my sound card.  I have set up my computer to work with line 6. None of this works. This problem just recently started.  Prior to that I experienced no problems.I am running Windows XP through my Dell laptop.  The computer more than meets the necessary technical requirements. Help!!!
Re: What is causing Guitarport sound cut outs?
by devilslefthand on 2010-01-23 13:02:48.7850
I'm having the same problem in everything (not just CD). Approx. every 30-45 seconds, my guitar cuts out anywhere from a split second to 2-3 seconds.
It worked fine last night but now won't. I've tried different USB ports, taking all peripherals out, unplugging and replugging, and nothing.
Any suggestions?
by devilslefthand on 2010-01-23 15:42:24.7340
Ok, I fixed mine. Was a latency problem. I went into the "Line 6 Midi Audio MIDI Devices" and slid the buffer rate to the right, no more pops.
by matts5273 on 2010-02-02 16:43:11.6600
Same problem here.
