Main :: Vyzex Editor
Intial opening of VyzexPocket POD
by cdavis2047 on 2010-02-28 13:40:50.2670
When I try to open Vyzex Pocket POD I get an error message: "This application has failed to start because InAMidi.dll was not found. Re-installingthe application may fix this problem."  when I look in C:\Program Files\Psicraft\Line 6\Vyzex Pocket POD\Win32 I find InMidi.dll.  Since the application was installed in C:\Documents and Settings\Chuck Davis.GECKO\Desktop I transferrred a copy of InMidi.dll in that folder with the same result.  It would be great if you could help me just get started using the Line 6 Pocket POD download facility.  I hope I didn't just buy a gizmo that I can't use with my DELL PC.
RE: Intial opening of VyzexPocket POD
by ricksox on 2010-03-03 14:40:55.1460
Hello,
Are you installing the Vyzex editor from the disc or have you tried downloading the latest version from http://line6.com/software/?
Line6Miller
Re: Intial opening of VyzexPocket POD
by cdavis2047 on 2010-03-03 20:29:11.0040
Thanks for the help. I was able to move the application from the My documents folder to the Line6/Vyzex folder and all worked well. Don't know why the application got into the "Documents" folder. May have put it there on installation unknowingly.
