Main :: Spider IV/Spider Online
Will laney 16 ohm cabinet (280 watt. non stereo) work with the spider III 150 head?
by msmtrock on 2009-03-29 10:15:09.4740
I want to purchase the spider III 150 head, I have a Laney cab loaded with the celestion speakers. The cab is a non stereo 16 ohm 280 watt. Will this head work with this cab? I do have top and bottom cabs but only want to use a half stack.
Re: Will laney 16 ohm cabinet (280 watt. non stereo) work with the spider III 150 head?
by Line6Hugo on 2009-04-01 11:35:14.7060
msmtrock,
Both speaker outputs of the Spider III HD150 must be connected into it's own 8 ohm speaker jack. They can each connect into a 16 ohm connection, though you will lose volume, but that means your speaker cab will still need 2 jacks at 8 or 16 ohms each.
Please go over the following document for more info:
http://line6.com/community/docs/DOC-3833
Regards,
Line6Hugo
by oldgitguy on 2013-03-15 20:31:19.3740
I have my spider 150HD hooked to a Peavey 412 Windsor with a speaker cable from the left channel on the head to the only 16 ohm input on the cabinet. It works fine but I do not use much volume. Sound comes out of all 4 speakers.
by fflbrgst on 2013-03-16 19:01:23.4280
This will eventually cause damage to your amp due to the output imbalance.
by oldgitguy on 2013-03-22 20:12:50.5780
Yes. Now that the amp is fixed I rewired the Windsor cabinet with a dual 8 ohm jack plate and it works great. The Supreme XL speakers sound awesome.
