Main :: Flextone I / II / III / Duoverb / HD147
Flextone III Registration
by royleith on 2010-04-22 03:47:51
I registered my Flextone III in 2007, but Monkey always claims that I haven't registered it, yet. When I go to the registration web page, it is already entered.This is with the Flextone appearing as connected in Line 6 Monkey.
This has happened for some years. This time I tried to add a new registration, but the web page said it was already registered. Line 6 Monkey still reported it as unregistered.
Then I removed the original entry and added a completely new entry which duly appeared in its registered item field. Line 6 Monkey still reports it as not-registered.
By offering to register later, I have been able to update Line 6 edit, but it is an irritating feature.
Regards
Roy Leith
RE: Flextone III Registration
by Line6Tony on 2010-04-22 11:28:53
Roy,
We have seen this before and have logged a bug with our IT group. Hopefully it will be resolved soon. Thanks, and sorry about the inconvenience.
Line6Tony
Re: Flextone III Registration
by s0c9 on 2010-04-23 07:59:15
Roy,
it's probably out of warranty by now, and I wouldn't worry about it.
If you search the forum you'll find a number of posts on this issue.
Registration gives you nothing special... except formal warranty coverage.
and as a 5yr user of my F3XL....
I HIGHLY RECOMMEND you DO NOT USE LINE6 MONKEY with the FlexIII.
Firmware upgrades FAIL more often than not, and backups that Monkey makes of your patches CANNOT be restored!!   USELESS !!
I hate to say it, but Monkey does not fully support the Flex series.
Use L6 Edit for editing and patch library management if you want to deal with Java (or Tweakwiz at vettaville.nl for C++).
If you need to upgrade/downgrade your firmware, use this L6 utility - that's what it was built for (by Line6, not me)
http://steve.sideroadsband.com/FlexUpdater.rar
You'll need to unpack it with something that supports the rar compression format (winrar, winzip)
But it works !!   unlike the "maybe" you get with Monkey..
Good luck !
by gtnapo on 2012-04-28 05:36:55
man this .rar is the upgrade of the flextone 3???
by rockabillybob on 2012-05-10 15:37:23
I just scored a mint Flextone III Plus for 150.00!
I was able to regester  it as well (guess the seller never bothered to register it)
The amp sounds great I was wondering what replacement speaker ppl use, I have some vintage 30's,70/80's and some G12-H 30 hellatones lying around
how do i turm the cab sims off..i want to run it through with my stereo 4x12 cab
Thanks Mates!
