Main :: Spider I / II / III
spider II 30 watt disable preamp?
by darknes-shreder on 2010-05-04 15:24:35.5200
I have a floor pod plus and when i play through my spider II 30 watt amp it get bad noises and interference even on clean setting. is there any way i can play my floor pod plus through this amp effectively?
Re: spider II 30 watt disable preamp?
by Nick_Mattocks on 2010-05-05 10:30:06.7210
I'm not familiar with the Spider II 30 watt amp.  Does it have a CD/MP3 input?  If so you could perhaps use this to feed in a signal from your Floor POD
by darknes-shreder on 2010-05-05 15:51:00.8690
tried last nyte and got no sound, i used the dumby lead and all that too, will try again tonight cheers
RE: spider II 30 watt disable preamp?
by AParedes on 2010-05-05 16:22:35.0710
Hello,
Here is an FAQ that may help:
Q: Can I bypass the preamp section of my amp to avoid stacking two preamps?
A: Yes, There are two ways this can be accomplished.
1) If your amplifier has a CD/MP3 input you can go directly in the this jack from the POD output (This is a common method with the Line 6 Spider Series amplifiers). Be aware you may need to "trick" your amplifier input by using a 1/4" dummy plug in the instrument input to allow signal to pass to the speaker (headphone adaptors often work well for this purpose).
POD Connections, Routing and the 4 Cable Method
http://line6.com/community/docs/DOC-4742
