Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
E1 shows in Display
by joepastori on 2010-05-23 19:31:49.6950
My Floor POD is not responding and is showing E1 in the display. Any idea what this means?
RE: E1 shows in Display
by Line6Hugo on 2010-05-25 16:37:07.5790
Not sure what that could be, but you should try resetting the Floor POD with the following procedure:
Hold MOD and DELAY while powering up. When “01” appears, disconnect power. Power up.
If the problem persists, you will need to contact an authorized service center:
http://line6.com/service_centers/
Regards,
Line6Hugo
Re: RE: E1 shows in Display
by joepastori on 2010-05-26 18:01:58.2700
Looks like I have to have it serviced. Actually what happens when I plug it in is all the lights light up briefly, 13 appears in the display, then 00, then E1. None of the controls respond, nor the pedals.
Re: E1 shows in Display
by muchris on 2012-11-24 11:18:09.5740
Same here. Can i fix the problem myself? Or is there any service center in Berlin, Germany?
by toneman2121 on 2012-11-24 11:38:26.0210
Service Centers Contact Info
ASA-Akustik Stiegler Kirchenbühlstr. 2 D- 90518 Altdorf 09187-804110 (phone) 09187-6546 (fax) ASA-Stiegler@gmx.de www.asa-stiegler.de
Beats & Bytes Darmstaedter Str. 21 Dietzenbach 63128 +49 6074 309848 (phone) kontakt@beatsbytes.de www.beatsbytes.de
PMS electronics GmbH Große Heide 27 32425 Minden +49 (0)571 64600 0 (phone) +49 (0)0571 64600 10 (fax) info@pms-electronics.de www.pms-electronics.de
