Main :: Spider Jam
foot pedals.....which are compatable with spider jam
by jlaselle on 2010-06-09 20:10:59
Which foot pedals are compatable with the spider jam..  What are the options and which gives the best overall functionability?
Jim
Re: foot pedals.....which are compatable with spider jam
by joegillespie on 2010-06-10 01:51:07
The FBV Express and FBV Shortboard are suitable for the Spider Jam. Both will give full controll over recording/looping, tuning, tap tempo, volume and wah. The difference is only in the number of USER presets you can access from the pedal.
The Shortboard can access all 9 banks of 4 USER preset tones from the pedal.
The Express pedal can only access one bank of 4 USER tones at a time.
If you play live and need easy access to more than 4 tones, the Shortboard is the way to go. Don't be confused by the MKI/MKII classifications. As far as the Spider Jam is concerned, they are identical in function.
by Avengeror on 2010-06-12 10:02:24
I am having trouble with New Shortboard not functioning with my New Spider Jam. I have up-graded firmware to 2.09 and it still doesn't work. The pedal lights up, but the pedal and none of the buttons work. I read on forum that firmware up-grade should make shortboard pedal work. I guess I'll have to contact technical support to get dialed in.
by joegillespie on 2010-06-13 01:05:59
You may have to calibrate the pedal
http://www.guitars101.com/forums/f81/line6-fbv-shortboard-41204.html
by bluesdelux on 2010-06-18 10:23:20
does the fbv express mkII pedal have the ability to turn effects on/off with the spider jam?
by Buy-a-Fender on 2010-06-18 10:53:22
not really switching effects on/off - it allows you to select from user presets programmed in the amp or you can use the foot switches to control recording/playback functions.
the volume pedal can be switched from volum  eto wah
both express and shortboard have same functionality - shortboard just gives you more user presets to switch among
by bluesdelux on 2010-06-18 11:03:15
I guess the work around would be to have the footswitches set up so that one has the effect on, and the other off.  Is there any delay between switching?
