Main :: Vetta
Vetta 2 boot issue.
by crazyfastkeys on 2010-08-17 14:40:57
I couldn't find any other instances of this particular malfunction so I decided to share it here.  I've got a vetta ii here that won't shut down.  As soon as it's plugged in it turns on and the power switch does nothing whatsoever to it.  It functions flawlessly, except that it is immortal.  Does anyone have any suggestions about what to do with a zombie vetta ii?  It's not hindering my musical endeavors but it still needs to stop.  I'm going to update/flash the firmware later and i'll repost if that does anything.
RE: Vetta 2 boot issue.
by Line6david on 2010-08-17 16:14:56
I doubt this could be a firmware issue. It sounds like a broken on/off switch. you need to take it to a service center for repair.
http://line6.com/service_centers/
The Vetta won't be under warranty but it should be a fairly cheap repair.
Thanks,
David
Line 6 Customer Support
Re: RE: Vetta 2 boot issue.
by xCaptainx on 2010-08-17 17:36:24
I bought a 2nd hand Vetta with this exact same problem, it cost $80NZ (probably $50 american or so) to fix. No worries.
Then I the PCP board died when trying to update the firmware
Re: Vetta 2 boot issue.
by Hento on 2012-12-03 14:30:27
Hi don’t mean to hijack your thread but I am having the same problem on my 6 year old Vetta II.
The thing is I live in northern Sweden and the closest line 6 support seems to be located in Germany more than 1k miles away.
Can I buy a new power switch somewhere and replace it myself?
by DickFoster on 2012-12-03 17:11:59
Yes you can. Is it a head or a combo? It's a somewhat common snap in rocker switch.
Just find a good electrocics guy to sort it out for you. There is not point in taking it to a Line 6 shop as they can do little for your Vetta. If he's a friend, it shouldn't cost you more than about $10 to get it put right.
by Hento on 2012-12-07 10:58:28
Thank you for your reply:)
It’s a head, I'll ask around and see if there is anyone locally that can help me
by DickFoster on 2012-12-08 15:13:39
From the pics in the service manual it looks like they are only using half the swich. It's a DPST for double pole. single throw.
Perhaps you or your electronics repair person could pop it out then move the slide on terminals to the other half of the switch and it will work for ya. Of couse it could be buggered inside so that may or may not work. Some switches you can take apart and repair but as I said it's a common enough switch that you should not have any trouble finding a replacment for it. If you get an electronics guy who needs the service info, shoot me a PM.
by Hento on 2012-12-09 02:22:16
Yes that is true and I know for a fact you can actually move the terminals, because I did, about a year ago when I had the same problems:).
After that everything worked fine...
Until now.
For anyone else who is experiencing these same problems for the first time, I can tell you that accessing the switch and moving the terminals is relatively easy and only takes about 5 minutes.
But as always with electronics you need to be very careful and first ask a professional for help, because circuits with capacitors will maintain their charge for a time even after you disconnect the power cable.
by DickFoster on 2012-12-09 08:58:32
In that case you shouldn't have any trouble fixing it yourself. Just remove the switch. Compress the lock tangs and pull it out of the panel. Get a ruler to measure it with then look at some electronics parts outlets for a replacement.
Try DigiKey http://www.digikey.com/?gclid=CKf-96PkjbQCFSmCQgodhiAAjQ&WT.term=digi+key&WT.medium=cpc&WT.campaign=Brand+Sitelinks&WT.srch=1&WT.content=text&type=Phrase&WT.source=google&network=g&adpos=1t1&WT.mc_id=Brand+Sitelinks&cshift_ck=335703CD-D083-4C50-8100-A426DFBA16DDcsx3wnxTIR
or
MouserElectronics http://www.mouser.com/?cm_mmc=google-_-ppc-_-americas-_-Competitors&gclid=CPuS55DkjbQCFUjZQgodZncACg
oreven your local Radio Shack maybe but they have been less and less valuable for electronics parts over the years so I don't go there much anymore for anything. I don't think they really know what kind of a store they are or what business they are in anymore so they turning out to be not much of anything and just not worth the effort. Not even for batteries as the corner hardware store has much better pricing on those.
