Main :: Lowdown
My amp keeps losing its volume
by kieraj on 2010-09-23 19:18:26.6820
As i was playing my new Line 6 LowDown 150, after about 2 weeks (this is the secodn week) the amp suddenly started having dramatic volume changes. I dont know what is going on, and it usually gets fixed when i reset the amp to factory resets, but then if i turn the amp off and then back on, it goes back to the way it used to be.
I have a five string bass, and it seems as though whenever i slap the low B string, the amp loses its volume.
It has been working perfect for the first couple weeks, Would you have any clue what is wrong?
RE: My amp keeps losing its volume
by Line6Hugo on 2010-09-27 13:01:27.9490
Is this a problem that only occurs when playing the low B? Does the volume drop affect the other strings after using the low B?
Does this problem happen with any other Bass guitars? Does your Bass guitar use active pickups? Have you checked that the batteries are in good working order?
Let us know.
Regards,
Line6Hugo
