Main :: Line 6 Lounge
POD HD500 and JTV-69 Clip U2 - Even Better Than The Real Thing
by stilwel on 2010-10-24 11:10:48.3220
Cover of U2's Even Better Than The Real Thing.  Gear Used:Line 6 JTV-69  Variax guitar on Rickenbacker 12-string model, Line 6 POD HD500 for all  amp/fx modeling, XLR outs direct to PC using TC Electronic Konnekt 8 and  Propellerhead Record.
http://soundclick.com/share.cfm?id=9742286
HD500 signal path: Boost Comp, Red Comp, Screamer, Pitch Glide (whammy),  Digital Delay (1/8 note), Digital Delay W/Mod (dot 1/8 note), Room  Reverb, AC30TB.    I kicked on the whammy for the intro and Red Comp for  the solo.
Re: POD HD500 and JTV-69 Clip U2 - Even Better Than The Real Thing
by aaron__aardvark on 2010-10-28 21:06:33.3080
stilwell,
I'm not sure if it sounds better than the real thing, but it does sound good!  Did you use a slide at all, or is it all pitch glide or ?  BTW, how is your new Variax at palm-muting?  If the Variax has a whammy bar, can you do decent dive bombs, or is it closer to a Strat whammy bar?
by guilhermebreda on 2010-11-14 07:57:05.5110
Sounds amazing!
and the tones sounds just as The Edge tones!
Actually, i had never seen a good cover of this song with another pod...
i'm thinking of buying a Variax, does it worth what you've played for?
And i also thought of buying the POD HD500 too, since the POD X3L doesn't have the same quality effects, especially a good pitch shifter and the octo-verb...
Is it so good as line6 says?
cheers!
by Vinnie2210 on 2011-10-22 07:09:06.0830
I tryd it and it sounds pretty good!
Do u also have some settings for other songs like Streets?
Just got the HD500 and im a bit new in it..
cyaa
