Main :: Spider Jam
How to record guitar and vocals together.
by dontfrett on 2010-11-20 14:58:42.7250
Kinda new to complicated amps and need some help. I have my guitar plugged into main inlet and a mic plugged in. When i press record and play a song on my guitar  while singing and when I am finished i push stop. And then push play to play back my recording. I get good loud lyrics but the guitar is very faint in the back ground.I have checked evrything I can any Ideas. Amp is Line 6 Spider Jam. Thanks in advance.
Re: How to record guitar and vocals together.
by Buy-a-Fender on 2010-11-20 15:23:59.4520
I'm guessing you already did this but.....
have you checked the levels?
Press the Level button and see what your levels are
by dontfrett on 2010-11-20 15:31:07.0430
I checked the playback levels and they are all at 100%.The mic is set at -4 db. If i plug the guitar into the aux port it will record with the vocals from the mic and it will play back when i push play but I can controll each individually
by dontfrett on 2010-11-20 15:32:41.6690
That was supposed to be (cant) control
by Buy-a-Fender on 2010-11-20 15:43:49.1430
I think the Aux/mik levels are controleld together - have you tired using the Guitar Input instead of the Aux and then adjusting levels?
maybe check page 3-3 of the Pilot Guide too
by Buy-a-Fender on 2010-11-20 15:45:25.0120
I'm assuming you've been through the the user manual but page 5-5 also shows some info on playback level settings
by Buy-a-Fender on 2010-11-20 15:46:39.4440
take a look at page 1-2 of the Advanced User Guide as well
by Buy-a-Fender on 2010-11-20 15:47:53.8610
if you haven't been to Joe's web site yet - you might want to read this
http://www.joesjamblog.com/multitrack.html
