Main :: BackTrack / MIDI Mobilizer
seems to be a bit of a common problem.....
by richastro on 2011-01-25 08:31:38.7170
my backtrack wont recognise on winows xp- ive reset it, the battery is charged and ive downloaded the set up utility, stil;l nothing.
it worked for the 1st 5 secs then nothing.  it only force captures, apart from that it doesnt recognise anything......
any help?
thanks
Re: seems to be a bit of a common problem.....
by richastro on 2011-01-25 08:44:17.8480
oh and it only records when i slam my pick against the strings
by richastro on 2011-01-25 09:01:08.2760
and ive tried resetting it, other cables etc etc
RE: seems to be a bit of a common problem.....
by Line6Hugo on 2011-01-28 11:54:38.3870
How long have you owned the unit and was it purchased at an authorized dealer?
Have you made sure to test all of your computer's USB ports? Have you connected it to a different computer or with another cable?
When you power it on (not connected to computer), how does the unit act if you just let it be, meaning, you just turn it on. What is the light scheme you see?
Regards,
Line6Hugo
