Main :: Variax Guitars / Bass / Workbench
Wires flattened and j shaped bread thingy?
by hotbody666 on 2011-01-26 04:32:12.3370
I keep reading on various post about the above.
Can someone just clarify for me that we are talking about the VDI cable? Also, would it be obvious to the eye that on of the wires has become displaced?
Thanks
Re: Wires flattened and j shaped bread thingy?
by amx05462 on 2011-01-26 04:47:08.4000
thats a tool fot  the  place  where you plug the  vdi   cable  in.    look in the  hole  with  a  flashlight . see if  any  of the  little  wires  are  compressed  or  if there are  any  pushed  to the  side.  the J tool made  from a bread tie  wire  allows  you  to  loop under the  wires  and  either  pull them up  or to one  side  or the  other. if  there  all even  and the  same  height   then this is  not  your problem.  as to the cable  itself   check it  for continuity  with  a  meter.
Re: (8>*}... always, always, always...
by JellyWheat on 2011-01-26 04:54:11.6380
... take amx05462's advice. He knows of which he speaks!
J/W
[A word to the wise is sufficient!]
by hotbody666 on 2011-01-26 04:55:21.1670
Once again, many thanks.
John
by JellyWheat on 2011-01-26 04:57:28.9330
You're welcome, John.
J/W
