Main :: James Tyler Variax Guitars
Support community for JTV.
JTV 59 malfunction other than know switch problem
by steele9999 on 2011-02-03 16:52:28.6730
I already have a support ticket open for my guitar on the JTV-59 switch issue. I know have another problem.
If I plug my JTV 59 into my POD HD500 everything seems to work properly (with the exception of the switch problem)
If I plug the guitar straight into a guitar amp (1/4" jack) I have no sound.
If I plug the guitar into the computer to use the workbench I get this message:
Could not connect to the Tyler Variax. Please check all MIDI and power connections and click refresh in the Tone Locker.
I tried that and can't get the USB port to see the Variax.  The connection module has a green light on the USB side but a Red light on the Variax In side.
Do I need another support ticket?  How much longer before the swithc problem is addressed?  Can this be fixed at the same time?
Thanks
Rick Sarlo
Re: JTV 59 malfunction other than know switch problem
by MartinHines on 2011-02-03 17:48:17.2440
When you plug into the Workbench USB device, do you also have a 1/4" cable connected at the same time?
I had a similar problem until I realized that at 1/4" cable must be connected in order for the JTV to use its battery.
If you are connected to another power source (like a POD) the JTV gets power from that device.  However with USB alone, the JTV has to be forced to use its onboard battery pack.
by ozbadman on 2011-02-03 18:28:50.1020
And actually, it sounds like your connections to your 1/4" may be no good. I think this may work if you plug into the VDI instead of the 1/4" since that will turn it on, but can't recall. ie: plug in the VDI as well as the USB.
by steele9999 on 2011-02-03 21:35:56.1850
Thanks for the info.  Last night I had the 1/4" jack connected and the USB port would not recognize the variax.  Tonight, I reinstalled the USB driver and got the same thing until I read your post.  Yes plugging in the 1/4" jack let Workbench see the guitar. Unfortunatley there is still no sound output from the 1/4" jack.
RE: JTV 59 malfunction other than know switch problem
by darealagentp on 2011-02-04 15:13:56.5010
Please check your Support Ticket: http://line6.com/account/tickets/view/
Our Service Department Administrator has sent you important info via the ticketing system.
Regards,
L6Perry
