Main :: POD HD
Line 6 Monkey fails to start
by musiknachtsmeer on 2011-02-05 11:12:32
I have installed the HD500 drivers, edit software and monkey as recommended. Edit software finds my HD500 OK downloads presets OK and Help, About tells me I have firmware 1.10.
When I start line monkey, I click on "I ACCEPT (and will be guided through the installation process)" as shown in ths screenshot, monkey continues tot load for a short while then for a brief moment it shows a message "Searching for all devices" as shown in the other screenshot and then closes down without warning or connecting.
I have tried re-installing. I have tried running bith Edit + Monkey separately and simultaneously, but the same happens each time. The crash log file is empty and attached.
Can anyone help me resolve this?
Cheers
Paul
Re: Line 6 Monkey fails to start
by Bluestone on 2011-02-05 11:16:20
HI
At this point it's a long shot..but if you are running Windows...be sure to have all the Service Packs on board...
I would have suggested deleting all the L6 stuff on your PC...and start fresh with first loading Monkey...then hooking up your HD...and up date to any newer versions...
OM
by nachtsmeer on 2011-02-06 11:04:43
Hi
thanks for the reply. Yes I'm running XP with latest SP3 and updates present.
I tried uninstalling everything and deleted line 6 folder. Then tried again, first loading Mokey as suggested. Same thing happened.
I then tried using a different machine (XP laptop) and it worked first time, so I updated the HD from there.
Will have to investigate further why my music PC won't load Monkey when I get chance.
Cheers
Paul
