Main :: POD HD
Pod HD500 "cuts" the sound when trying to record-play media
by maxguitarrista on 2011-02-06 18:09:06.0170
hey guys, it's my very first post , well, i've recorded with 0 problem connecting the hd500 to the usb port at my desktop ( 4gb ram and a AMD Phenom x4 955 cpu )using cubase as recorder, but when i try to record with my laptop (3gb ram and a intel core p8600 dual core)  the backing track recording randomly "cuts" for like 1-2s seconds in intervals of 10-30 seconds .also I can hear my guitar, but not the sound that is coming from my PC in those random"cuts". this also happens when i try to see a youtube video, or listen to music (with my podhd500 connected) and when I disconnect the hd500 I have no problems, I dont know if it's a USB problem or a cpu problem or whatever, please guys help me..
Best Regards.
Max
Re: Pod HD500 "cuts" the sound when trying to record-play media
by silverhead on 2011-02-06 20:17:16.4040
It sounds like stuttering to me, indicating that your computer is having trouble managing its resources (RAM, CPU) while communicating with the HD500. You might need to adjust the buffer size by going into the control panel called Line 6 Audio-MIDI Devices. Experiment with different settings and see if that helps.
by maxguitarrista on 2011-02-06 20:45:20.3940
well. I've already tried that, it doesn't work that much, it still stutters, i dont know what could be the cause, Any Ideas?
by Nick_Mattocks on 2011-02-07 06:55:26.5160
What make and model is the laptop?  Do you know if it utilises and internal USB hub and is it USB 2.0?
Thanks
Nick
by TheRealZap on 2011-02-07 07:53:44.8540
as an expirement i would try flipping of the wireless if you have an external switch to do so...
obviously you would need to have a local source to try playback...
but for some reason, i've seen the wireless card cause alot of drops like that.
by Nick_Mattocks on 2011-02-07 08:16:32.4350
Yes - good point re; the wireless adapter.  I forgot to mention it...
by maxguitarrista on 2011-02-07 12:58:55.6740
well it's a Dell studio 1555, and no, i dont know anything about the usb :S ... thank you very much
by maxguitarrista on 2011-02-08 09:01:56.4420
THAT WORKED!!! Thank you very much dude!!! the notebook had no external switch, but I turned it off manually from the devices manager.
I LOVE YOU hahahah
Best Regards
Max
