Main :: POD HD
Have we figured out what Volume pedals work with the HD 500 yet?
by Dbourget on 2011-02-14 13:16:20
Hi all,
I know we've talked about this subject more than once but it seems we never set anything in stone. I have the Line 6 pedal which Is ok but leaves alot to be desired for me.
Just what volume pedals will work with the HD 500?
Dan
Re: Have we figured out what Volume pedals work with the HD 500 yet?
by casparello on 2011-02-14 13:32:13
The problem is: You can´t connect every other pedal because you need a pedal with a 10k Ohm Pot.
I heard that the LVX-1 from Lead Foot works just fine. But I can´t tell for shure.
And the Line 6 EX1 pedal of course ...
by Dbourget on 2011-02-15 10:39:36
You are correct my friend. Thats why I'm posting this question to the community. Also, I want to replace my Line 6 EXP-1 which just doesn't cut it for me.
Does anyone out there have any input on the subject?
Thanks for the reply,
Dan
by talbotpat on 2011-02-15 14:14:30
My Ernie Ball 6166 works great with the XTL and X3L, but not so much with the HD500.  It goes from all the way off at the heel, to all the way up REALLY fast...like within the first 3/4" or so of travel.  Total deal breaker for using the 6166 in the Pedal 2 jack.
Pat
by phil_m on 2011-02-15 14:28:05
The Mission EP1-L6 is designed to work with Line 6 products.  I know that there were some issues with the pedal working with the HD line a few months ago, but I believe the guys at Mission have taken care of that now.  It's a heavy duty pedal in a Cry Baby style enclosure.
by Bluestone on 2011-02-15 15:02:20
I personally like the L6 exp pedal...I bought one to use with both my new HD 500 and my older X3 POD and Shortboard..
I'm not sure why the L6 pedal doesn't "cut it".....are not most expr pedals a one trick pony?
Anyway...that's just my take...if and when my L6 expr fails...I'll most likely buy another...
OM
by phil_m on 2011-02-15 16:49:54
I've mentioned it a few times here, but I've had two EX-1s for nearly 10 years now.  I've never had any issues with either of them.
by Dbourget on 2011-02-16 08:00:22
I've had a Line6 pedal since I got the XTL then X3L and now the HD500. When I was using regular amps with stomp boxes I always used an Erine Ball volume pedal and I guess I've been spoiled by the quality and the solid as a rock feel of it. Nothing against Line6 but the EX-1 is just very cheaply made (to me anyway) and just flimsy. I would love to use an Erine Ball as the EXP-2 but mine does not work in that slot and I've heard to many conflecting posts about the 25K OHM model working or not working.
I'd like to hear from some of the guys on this forum about what's being used by them as a volume so I can concider what to choose.
Thanks,
Dan
by TheRealZap on 2011-02-16 08:05:42
i've had my eye on those for a while... they look solid as a rock, and i've only heard good things about them.
apparently they work closely with L6 to create the updated version, since they even feature the L6 logo now.
by talbotpat on 2011-02-16 08:17:36
Thanks,
Dan
The Ernie Ball Volume is built like a tank and is awesome...the 6166 I have (250K pot) just won't get it done with the HD500.  I'm going to be on the lookout for a 25K Ernie Pedal and give that a go when I find one.  The Mission pedal looks interesting as well...I'm not really that high on the EX-1 either for the reasons you mention.
Pat
by Dbourget on 2011-02-16 10:20:58
I found this at the Mission-Engineering web site.
http://www.mission-engineering.com/Mission-Engineering/Support_files/EP1-L6%20Pod%20HD%20Compatibility.pdf
Cananyone confirm that this fix has solved the problem that their EP1-L6 pedal was having with the HD500?
Dan
by Dbourget on 2011-02-17 07:48:59
From what I've read, the 25K Ohm Erine Ball pedal won't  the trick. I guess the magic number is 10K ohm.
I really wish we could get more feedback from the community on this subject.
Dan
by Dbourget on 2011-02-21 16:57:17
Anyone?
by clantostheny on 2013-01-03 20:18:47
The very best pedal I have found is the Mission Engineering expression pedal EP1-L6.  It has solid construction and a very natural and smooth pedal feel.  It works perfectly out of the box with the M9 Stompbox Modeler.  However, to make it work optimally with the POD HD500 you will have to make a trivial modification.  At the time of this post (3 January 2013) the current production pedals do not work well without the described modification when used with the POD HD500.
See this post for details...
http://line6.com/support/message/403359#403359
">http://line6.com/support/message/403359#403359">http://line6.com/support/message/403359#403359
by mlong on 2013-01-04 05:48:50
Ditto what John says. I went around and around with Mission until they finally said that the EP1-LS issue is L6's problem since it works fine with the other L6 products. I almost sent it back, but opted to use the resistor method as described in the link above.
Rather than modify the pedal, I added the resistor to the 1/4" connector on the patch cable btween the EP1-L6 and the HD500. Just solder it between hot and ground.
by dbagchee on 2013-01-04 15:19:10
This is good to know. The Mission Pedal is built great and worked great with my M13 when I had it and just assumed it would be fine with my HD 500 but never got around to testing it.
by PDKTDK on 2013-01-05 06:44:02
I'm  using a roland ev-5.  It works well for any pedal function (volume, wah, etc).  I got it last week.
by CairnsFella on 2013-01-05 17:47:50
I have one of these. I'd certainly agree "it works" for wah etc, but I wouldnt say it is as smooth as the built in pedal for me (and I have tweaked the relevant parameters). Mines pretty old though (not that I think this really effects it, but I dont want to explicity doubt your findings, so maybe mine isnt as good as it once was).
by klarkkentster on 2013-01-09 07:49:58
I heard a couple guys are having luck with the Boss FV-500H. CAn anyone confirm? I am also wanting to purchase one.
by klarkkentster on 2013-01-09 15:53:11
This should help clear things up. I decided to get it from the horses mouth:  I am proceeding with ordering a Mission Engineering pedal
Thanks for contacting Mission Support. Any pedal ordered direct from our webstore, or that of our certified Mission Reseller Family, is guaranteed to have the most updated EP1-L6 components. Ordering a pedal from other sources such as Craigslist or EBay deems the products compatibility unreliable. The upgrade was made over two years ago, so the issue has long since been resolved.
Here is a link to the EP1-L6 and the Reseller page:
http://missionengineering.com/shop/ep1-l6/
style="color: #1f497d;">http://missionengineering.com/dealers/
style="color: #1f497d;">Let us know if you have any more questions.
Thanks,
Mission Support Team
Sent: Wednesday, January 09, 2013 7:49 AM
To: info@mission-engineering.com
Subject: Hd 500
Importance: High
I have heard there are issues with the Mission EP1-L6 pedal working with the HD 500 as an additional expression pedal. Can you confirm?  If they have been resolved how can I tell on the pedal I purchase it is one of the ones that has been fixed. I am planning to purchase a pedal today or tomorrow. A quick response would be appreciated.
thanks
by lebihanj on 2013-01-09 16:53:23
Message From Mission Support Team:
We fully understand the frustration surrounding firmware issues with expression pedals (including our EP1-L6) in regards to 'volume' control on the POD HD series. Customers have described that they are not getting the full 'range' or 'sweep' with an external expression pedal. We had considered designing something to remedy this issue, but that would involve making a new expression pedal with the sole purpose of controlling only volume on the POD HD series. We felt this would not be in the best interests of our customers to produce a pedal with such limited capabilities. We have brought this to the attention of Line6, as this can be solved within their firmware. What is recommended is using the 'stock' expression pedal already built-in to the POD HD series for 'volume,' and the EP1-L6 for all other expression capabilities (wah, whammy, etc..).
Whilst the recommended work-around is not perfect for some, it will go some way to solving this
If you have any questions, please feel free to contact the Mission Support Team via info@mission-engineering.com
You Guys Rock,
by mlong on 2013-01-10 05:51:53
I had the same response from Mission when I bought mine. I agree that the issue is with the HD500, but I still think it is being misrepresented.
It's not a "Volume" only issue. The issue is that the HD500 responds at 100% of whatever parameter it is controlling at about 3/4 of the pedal movement. The only way to currently correct that is to drop the  resistance of the expression pedal when it is at the toe down position. This is easily done by soldering a 22k ohm resistor across the jack of the pedal. Which is something that we shouldn't have to do with an expensive expression pedal(or any other pedal).
That said - it IS Line6's issue.  Since all of the other L6 products respond fine to the 10k pot in the Mission pedals, its rediculous that L6 doesn't fix this in their top of the line pedal. I have a very hard time beleiving that this would take them very much time to fix and test.
by clantostheny on 2013-01-10 09:27:12
I'm not sure your post "clears anything up."  But rather muddies the waters again.
Mission did indeed start sending out "resistor kits" when these problems occurred a few years ago, and back then it was "resolved."  But that was long ago, with a different pedal design that was in place before the POD HD500 came out.
If you ordered a brand new pedal from Mission Engineering, (at around the date of your post) it will have a resistance range from 0 to 10k, so if you want to utilize the full sweep of the pedal for any parameter (yes, any parameter, not just volume) you assign to it, be prepared for a trip to Radio Shack.
And by the way, the suggestion to utilize the on-board pedal for volume, and the Mission pedal for "other parameters" just doesn't work very well if the "other parameter" happens to be a wah-wah, since there is no button on the external pedal to engage/disengage it.
Until the "interface" problem has been resolved between Line 6 and Mission Engineering, the temporary "resistor mod" described makes the pedal work as intended, and it can be just as easily removed when the problem is resolved.
by phil_m on 2013-01-10 09:30:02
The thing that I don't understand about this issue is why the Line 6 EX-1 pedal works fine with the HD500 still. And it works fine with my M13, too. Theoretically, it has the same specs as the Mission Engineering pedal.
by mlong on 2013-01-10 09:41:20
Phil, I don't have the EX-1 to test so I'll assume you are right in saying that it works with the HD500. One thing that I have gleened from all the posts is that some people are more sensitive to the pedal range issues than others, especially depending on the parameter they are tying it to. For me the test is to use Edit, assign it to a parameter that shows percentage, then move it slowly until it hits 100%. For me, the Mission pedal(10k pot) had about 25% left in the sweep. The 22k resistor brought that down to the magical 6.8k range. I have to believe that the HD500 is looking for that value since it tests the same with any pot I tried. 100% = ~6.8k ohm. period.
What's the resistance of the EX-1 across the jack at the toe down position?
by phil_m on 2013-01-10 09:49:52
I haven't hooked up a meter to the EX-1 (perhaps I could try tonight), but I have used the EX-1 to control different parameters with the EX-1. I just didn't notice it working any different than I'd expect. I honestly haven't tried it in awhile. I have to give it another shot tonight. I never really like controlling the volume with the EX-1 anyway, because of it's linear response.
The one physical difference with the Line 6 pedal is that it actually has two 20k pots wired in parallel to achieve the 10k, but that really shouldn't make any difference.
by mlong on 2013-01-10 09:56:10
Two 20k pots in parallel? That's interesting. I wonder if they are different tapers or something, Two pots seems like twice the opportunity for issues!
by phil_m on 2013-01-10 18:45:09
OK, so I took some time tonight to do a little research into this, and, as it turns out, both of us are right, kind of...
So, first I took one of my EX-1s and plugged it into my HD500. I set up a simple patch with a volume pedal effect, and I set it up to be controlled by EXP2. I set the min to 0% and the max to 100%. Then when I rocked the pedal back and forth, I notice a similar thing as you're describing happen with the Mission Engineering pedal. I'd at about 80% or so through the sweep the volume pedal goes to 100%. So it does seem like the jack for EXP2 is set so that it needs to see something less than 10k ohms to go to max.
However, just because I was curious then, I hooked up the EX-1 to my M13. I set it up to control the volume pedal effect again with heel at 0% and toe at 100%. What I found surprised me. The pedal exhibited pretty much the same behavior. By the time I was at 80% or so, the volume was at 100%. I've been using the M13 for over 4 years now, and this is something I've never noticed! I think it's probably I do not really use the expression pedal to control volume, but rather different parameters.
One thing is that I think the actual construction of the EX-1 is such that by the time it's at 80%, the treadle itself is almost at horizontal, and when you're actually stepping on the pedal, you hardly notice that little bit of extra travel down to the toe stopping point. The only thing I can think is that perhaps Line 6 intentionally wants a little wiggle room at the top of the sweep because that part is the hardest to accurately control. I would venture to guess that the EX-1 works the same with all Line 6 products with the expression pedal input. Perhaps because the Mission Engineering pedal is using a pedal design where the toe-down position isn't really horizontal this extra travel is more noticeable.
Also, I should add, just to check, I did measure the resistance with a multimeter, and it was 10k ohms.
